Get some Silicone Grease and The Right Stuff RTV.
The grease gets applied to the axle seal where the axle shaft rides and the RTV gets applied to the outside of the seal. Do one side at a time and allow the RTV to cure for a few hours. You don’t want the RTV to come in contact with gear oil before it cures.
Same shop fixed the seal on the other side last time. Both times. Reputable shop i believe.
It's a 4x4 shop so i'm assuming they know the better brands to use.
And why not exactly? The grease keeps the seal from suffering heat damage and also conditions the rubber. The RTV helps ensure no leaks between the seal and the axle tube.I wouldn’t go this route myself, just get a proper seal and do it right.
https://www.stu-offroad.com/axle/usad44/usa-2.htm
Some signs of leaking around the pinion.Usually if the breather vent is stopped up you will see seepage around the pinion seal and the cover, any sign of leaking there?
So, how do I check the breather line for clogs?
mine is like yours. When I take off the clamp, no fluid should come out right? I get pushing air thru the tube, but back in the block? Is that ok to do?The differential breather on a TJ is a bastard setup. There is really no reason for it to be tied to the block for the brakes. On mine there is just a low pressure hose with a hose clamp. i would think you could just take the hose off and blow a little air back into the block, maybe stick a piece of wire in to see if it is open. How bad is the leak anyway? just seepage or continual leak?
No fluid should be up in the hose, the differential should be 0 pressure, the only pressure should be minimal due to temp change. I have never checked the vent on the tj, on the old Willys it’s just a simple fitting on the diff case. As suggested, take the hose off blow very low pressure thru it , then take a wire and see if the block is open back down into the axle tube.
