Arb Compressor percolating oil
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
Even when it isn’t in, gear oil seems to be coming out of these -
..are these relays that stop back bleed
Those are simple solenoids that open and close to allow air to flow from the compressor to the locker. They don't have a check valve that I'm aware of.
One of the reasons that it can back up is if the installer didn't grind a return drainage slot at the bottom of the axle tube.
It is common for gear oil to eventually work it's way up to the solenoid. To clear it out just disconnect the air line from the bulkhead fitting on the axle and run the compressor until it clears.
Some people will go as far as to add an oil separator between the solenoid and the air line.
Reactions: 1o1proof and AndyG
Thank you for such a good response can you elaborate on that just a little bit
Cut a slot using a dremel about 3/8" wide right there. It allows oil to drain back into differential and get back in the cycle. Only need it on the rear axle as the front axle seals are inboard.
