Yes I am running All Terrains. Because it is my dd and I cannot justify having a second set of wheels yet.
Even 20 psi that you recommend for on road (which seems a bit low for me) would be somewhat of a air down compared to my current 29 psi on road
I said 22# on road...
But you evaded my other question/point...of the need to air down off road.
Are you really starving for more traction?
I truly appreciate your excitement of getting into the wheeling/Jeep world...but don't just start doing stuff because you've heard of or read of....
like someone airing down tires....just to do it.
Let me be crystal clear on something. This is on text so you can't tell my tone or intent...but I assure you I'm not being malicious whatsoever when I say this.....
You're removing a lot of the fun of off roading. Many of your questions are things you should be learning on your own...(part of the fun of off roading)
Like your question of airing down you even asked what psi on what terrain? These are things that you should be learning on your own. Again part of the fun of off roading.
Are you going to come to a trail head and see greasy, muddy, hilly, rocky terrain....
pull over...
whip out the phone...
post up a question...
hope for a quick answer...
before proceeding?
Questions are a great thing and can help a lot of people with a lot of things....
but....
asking questions pertaining to actual driving is being counterproductive.
You'll be a much better off road driver by experimenting with your machine and different situations and scenarios if you just get out there and do it.
You need to get out there...
play around, get muddy, get some undercarriage scrapes, get some close call stuck situations...get that intimidated feeling but try it...then that super hero feeling after you've conquered it...
^^^this is all part of the fun^^^
*****To add*****
My advice to you is this...
Whatever psi you're running on the street....run the same off road. Especially running All Terrains. It will make you a much better all around off road driver and give you a lot more knowledge than having us on the forum drive your Jeep for you.
Running your street psi will teach you the variations of wheel speed...(sometimes less is more...sometimes more is the only way)...sawing at the wheel to find the last little bit of traction....etc etc...
All of which nobody here can teach you. It's just something you need to experience and TRUST ME...You'll have much more fun trying things out and learning. Learning terrain, your tires and what they suck at, learning your machine, learning the proper gearing for a condition (low range/hi range and what gear on your tranny.....
Plus a million other intricate things while wheeling...
all while honing your driving skills.
Trust me my friend....get on the horse and gggooooo!!!
