Mashed the drivers side front lower control arm bracket beyond repair - might as wells replace both fronts. Sounds like Iron Rock are the go to with the RockJock mini-skids? What bolts do you use to attach the Control Arms?
One question - I notice they do not have the mounts for the cam bolts so no camber?? adjustment? Is that because they are for use with adjustable control arms, so not needed?
Any other brands to consider or any other advice on replacement?
Any help appreciated.
