Give the MTL a few thousand before you pull the trans, mine didint do much the night I swapped it, but was loads better after about 1,000 milesReceived the Redline MTL and ended up making the switch today. Didn't make a difference in my case sadly. I am able to shift smoothly through all gears if I shift relatively early but as soon as I up the rpms to about 3k or above it'll grind into third and only third. Also grinds if I try to downshift into 3rd. It does not pop out of the gear or anything else.
I am not aggressively driving the car when this happens.
This jeep only has 87k miles but it looks like my synchro might be going out in that gear. Guess it was just a coincidence that it occurred all of a sudden when I changed the trans oil. Im going to start saving up for a possible new trans.
Thank you guys for your help.
Does this problem get any better or worse with trans temp?
