The TJ engine bay is very open as far as "newer" vehicles go. Not quite as open as a 1974 CJ but open in comparison to newer autos.Mine are under the hood on the fender well. I’m considering hood louvers to draw some of the excess heat out but haven’t read enough about them yet. It may be a non issue, but with louvers the potential to let water into the engine bay in heavy rain concerns me. Eventually the plan is high line fenders so I may need to relocate them in the cab eventually anyway.
Do you plan to never drive in any rain?but with louvers the potential to let water into the engine bay in heavy rain concerns me.
That is not actually a bad thing. If you smell gear oil due to the airline, that means the actuator is compromised and needs repair. Otherwise the air side and oil side of the actuator never mix.Do they permit air to retract back to the compressor when not running? My only question would be the smell of gear oil inside the cab.
Set it for 5 psi and you'll be fine. What are ARB regulators?Putting them inside would be trivial, but if you have the OEM fenders you could mount them under the ABS tray, it's mostly safe from the elements.
However whenever my hilines ship I'll likely drop them and use the ARB regulators once I can measure the OEM pressure to match it exact.
Just knowing how the rubi lockers are getting more expensive and harder to find I set out to give myself another option. I picked up the ARB replacement solenoid (sorry I used the wrong term previously), a 1/8 male BSPT to 1/8 NPT and a 1/8 male NPT to a 5/32 barb. I may optimize this later to remove one of the connections, this was just what I could do on Amazon. I’ll run everything off my single can ARB.Set it for 5 psi and you'll be fine. What are ARB regulators?
Looks like ARB came out with a new product recently.Set it for 5 psi and you'll be fine. What are ARB regulators?
I looked to find out what the adjustable range is, but didn't see any published information.Looks like ARB came out with a new product recently.
https://www.amazon.com/dp/B07DXDMFL8/?tag=wranglerorg-20
I wonder if this is what he was referencing for the "ARB regulator". Little info but it appears it's controlled by an APP? I might pass if so.
Personally I would not trust any regulator that goes high enough to fill tires. You are looking for something with a 0-15 PSI range to run the Rubicon locker actuators.I looked to find out what the adjustable range is, but didn't see any published information.
That was my exact thought when I looked at this a couple years ago. There were no regulators with a wide range, at least high enough to inflate tires, that I would trust with the factory 5 psi locker actuator.Personally I would not trust any regulator that goes high enough to fill tires. You are looking for something with a 0-15 PSI range to run the Rubicon locker actuators.
