So, following advise here I’m trying to diagnose the ‘ not starting 1st time but always second issue’. I believe it’s the fuel drainage issue requiring a new pump. However...
Today , I went to check the fuses and relay and found that the fuel pump relay is very loose. It is literally just sitting in its place held by gravity it’s that loose.
All the other relays are fine and push in as they should nice and snug. The fuel pump relay just drops in as I said With only gravity holding it in place.
I’ve tried other relays and they too, in this fuel pump relay socket just drop in almost not even touching the sides?
I’ve never come across this before , any tips how to fix this?
thanks as always...
thanks as always...
