LJ rear cargo storage
I don't use my soft top anymore, but when I run my hardtop with the roll-up soft sides I use this trunk box from Gr8Tops for secure storage, it's designed specifically to fit in the LJ and makes optimal use of the cargo space in the LJ.
I've had it a long time, I used it with my soft top before I switched to the Safari Cab hardtop...
The box will fit under a tonneau cover.
That is great option. Thank you
Ohh, well usually I toss my strap and the pouch I keep my shackles in under neath it.
it can definitely be bolted inthrough the floor if you want to go that route, but I havent found that to be necessary
The heavy weight of those keep them in place pretty well huh? It’s hard maximizing security/space/weight sometimes, that’s my struggle.
Looking at Home Depot I see that it’s raised off the ground with what looks like fork holder
I made my own. Well designed it them had a place cut and bend the steel for me. It has a piece on top with a lip bent down. And bolted to a piece that rides along the back seat. The back seat piece is held down with small turnbuckles into the anchor points in the floor. I then put a piece of angle aluminum on the tailgate to hold the front edge from being lifted up. If anyone's interested I could take some more pics and figure out how to get the measurements on here.
Wow. You did nice job. I really like that. Clean and simple with great security.
Is your box from Gr8tops or did you pick it up somewhere else?
I designed the Gr8Tops box and mine is the preproduction prototype. The only difference betwen mine and the production box is that I made the production box slightly lower so it can fit under a tonneau cover, after I had the prototype built by the box company I decided it was slightly too tall.
An original design sketch:
And before having the prototype made, I made up a scale model in cardstock:
In the process I also designed a few other TJ/LJ storage boxes, but Gr8Tops decided not to put them in production...
I'm sure that's way more information than you wanted, but I came across these images and thought it would be fun to share them :).
I like concept #4. Stuff just accumulates in those foot wells when I’m wheeling.
you have some great ideas.
Reactions: Viking Jeeper
No way, I love your designs/drawings, and I was hoping to get an answer like this.
Mine is secured to the tie-down points on the floor.
What did you do to pick up the tie down points on the floor, did you use a turn-buckle like an above poster? Do you have a picture of the mount? I just got a GR8TOP box and deciding how to mount it now.
When I designed the box for Gr8Tops, I wrote a draft document describing how to mount it in early and late model LJs (they have different tie-down points). I intended that Gr8Tops would include the information in whatever instructions they included with the trunk box. I don't know if they ever did include any instructions, so here is the original draft I did years ago.
FWIW, these photos were taken in my 2006 LJ and the box gets mounted this way every time I install it. I've never had any issues with it moving. (Photos of my LJ are in post 3 in this thread, I won't repeat them here).
Thanks very much for that, no, they didn't include any instructions with the box. I like the J-hook idea.
@Jodh do you have CAD for this available?
