Vibration after installing 2.5” lift
vin94200
RI
Installed a 2 1/2 inch on jeep tj, before i did the jeep ran fine now im getting vibration . i thought it was suppose go smooth with no changes because its only 2 /12 inch. guess that bull. Ineed some help !!!
Same thing happened to me. You need to drop your transfer case about 1".
I matched the bolt thread at Home Depot but got 1" longer and used two nuts as spacers between the frame and skid.
You could buy a TC drop kit but this is cheaper and quicker. I'm putting a SYE on soon so I didn't care about getting something cleaner
Have you measured the springs to see how much actual lift you got? Advertised lift height is often not what you get. Easy fix is a transfer case drop or motor mount lift. I'd personally lean towards the motor lift as I feel lowering the pan looks bad and defeats half the clearance gains you made with the lift.
After installing a ProComp 2" lift on my '01 Sport I also had driveline vibrations which required me to install a TC drop of 1".
The SYE really is the proper resolution to the vibrations, but the SYE kit and driveshaft will cost $400-800 and that doesn't include $500-800 in labor ( depends upon local labor rates ) IF you cannot do the work yourself...
IF you decide to install the MML; check the cooling fan blade shroud clearance after you installed the motor mounts.
It just goes to show that every Jeep is different. I've lifted both my Jeeps 2.5" (1 Rubicon, 1 Sahara) and never had any vibes. All control arms and driveshafts were stock.
Reactions: AndyG
Some springs are not the advertised 2.5"
Condition/age/mileage of your u-joints are?
We've installed several 2.5" springs (legit 2.5") and if the u-joints are good or replaced with new no issues.
Did you get different tires with the lift?
On a side note were you installing just for a look or off road function. If for off roading did you get swar bar disconnects for your new lift height?
No i have p 225 still 15 inch im going this week to find some . im thinking 32 inch with 15 inch rims x 10.
I wish. This happened on a 4 inch lift with a 1.5 inch tc drop.. almost a year ago too. Stock driveshafts too. Just rebuilt the tranny too and it went kaboom because of u joint failure. It was giving 0 vibes too until it all of a sudden broke. I bought a junkyard one and put a sye and have had 0 problems since lol
  • Wow
Reactions: TheBoogieman
Hot damn.
Vibs or no vibs is not a good rule of thumb as I have come to learn when making sure the drive line is dialed in but to each their own.
Should we do an alignment first, could that fix it? Or go right to the TC drop kit. I don't feel paying the dealership twice for an alignment, assuming you would need an alignment again after a TC drop kit.
I'll assume you're getting vibes after a lift.
You'll need to determine if it's from the rear driveshaft, front driveshaft, or front tires.
A TC drop kit helps with rear driveshaft vibes and will not affect the front alignment.
