Been saving and today I saw this…
Is that a bad thing? Besides, look at her - ain't she purdy?!?!
I was asking about the engine specs the 2nd guy wrote on - it goes without saying that if you buy a used vehicle with any kinda mileage, you'll want to check the body and frame up close and in person before making a decision. I'm not an engine nut of any kind, so was asking about this part:
An 05' auto with Dana 35 rear axle and 3" BL.
I get the '05 part (year)
I get the auto part (transmission)
But the Dana 35 rear axle made me say "huh?"
And the 3" BL also made me say, "wha...?"
A little clarity on that would help... :)
Never mind, has an accident in it's history from a VIN lookup. Oh well...lol
05' autos have pcm problems that now can be fixed by Wranglerfix. OPDA issue can be fixed or delayed. Dana 35 axle is fine, unless you go with much larger tires. A 3" BL is a no no. Rule of thumb is a 3" BLT is good, a 3" BL not so much. :unsure:
It's a pass.
It's also freshly hosed down, which always makes a car look better in photos
For future reference-common terms & abbreviations
  • BL= body lift, spacers between tub and frame to gain extra wheel clearance, over 1.5" is generally not good functionally or aesthetically
  • BB= budget boost, aka spacer lift, spacers on top of stock length coil springs to gain lift, not as desirable as a spring lift
  • SL= spring lift, longer coil springs/shocks to gain lift for larger tires and more suspension travel
  • TC Drop= Transfer Case Drop, spacers added between frame and TC skid to correct driveline angles from adding lift
  • SYE= Slip Yoke Eliminator, optional kit to eliminate vibes due to large lifts, requires other modifications
  • MML= Motor Mount Lift, used to correct driveline angles and/or in combo with BL to keep engine fan shroud in stock mounts
  • D 30= Dana 30 axle, common front axle in many TJs, not as strong as Dana 44 but fine in most cases
  • D 35= Dana 35 axle, common rear axle in many TJs, not as strong as Dana 44, normally ok with up to 33"
  • D 44= Dana 44 axle, optional front and axle in many Tjs, stronger to allow for larger (33"+) tires, lockers
  • LSD= Limited Slip Differential, allows an amount of traction in both wheels on the axle, not a full locker
  • TT= TrueTrac, a brand name of a gear driven LSD
Pretty expensive for a non rubicon.
I was searching hard recently before I got my lj and 13.5 would get a pretty clean rubicon tj or non rubicon lj with similar mileage. And that’s New England pricing where a clean frame fetches a premium.
And the spare doesn’t match.
Reactions: CBJason
I was thinking the same thing with pricing. Take it down $4k and maybe after they remove that body lift, then we’d be talking
Negotiate down a bit or keep looking. I snagged a 03 Rubicon 137,000 miles for $13,500 a few months ago.
