Mopar's CCC is 99% water and 1% ammonia as a detergent. You can do the same with plain old ordinary tap water. Yes that is absolutely true.
Fill a soda can with water then start the engine. With the engine idling, SLOWLY (!!!) trickle the water into the throttle body. It should take a couple minutes to empty the can of water. Don't dump the water in too fast, that can cause bad problems for the engine. I suggest the soda can because it holds the right amount of water and it's easily controlled so you don't accidentally dump too much in at once.
The water is highly (!) effective at getting rid of carbon deposits. This was discovered during WWII by engine mechanics. Water injection was added to bomber engines to give them more power so they could take off more easily and cruise at higher altitudes with heavy bomb loads. The engine mechanics were happy at how clean the engines became with the water injection. Which by the way is still used today in some engines.
