Mine is too. So inspirational than I'm getting ready to replace it!No I’m referring to the brake hard line. It’s inspirational
Sure does. I know Matson used to have an account...I remember yours now. It makes you wonder...
@matsonsianSure does. I know Matson used to have an account...
Make two!Mine is too. So inspirational than I'm getting ready to replace it!
I am delighted that your delicate items appear to have arrived unscathed. Kudos to our packaging team. FYI, that is not your average expanding foam. That there is full encasement delicate item high protection expanding foam, 2 part, 4 lb density for the highest protection level possible in a cardboard box full of breakable items. It even floats in the event that your items happened to encounter flood stage waters during the trip.@mrblaine was kind enough to send me one of his special boxes of expanding foam. I can't thank him enough for extending his famous kindness and generosity in my direction.
My hope against hope is that the first box that was about to go out received the same careful treatment!I am delighted that your delicate items appear to have arrived unscathed. Kudos to our packaging team. FYI, that is not your average expanding foam. That there is full encasement delicate item high protection expanding foam, 2 part, 4 lb density for the highest protection level possible in a cardboard box full of breakable items. It even floats in the event that your items happened to encounter flood stage waters during the trip.
I’m interested to follow the install and read your review.My hope against hope is that the first box that was about to go out received the same careful treatment!
Two are free. I had to take a quick break before tackling the others...
This will be a winter project. Once I found out that the 35" MTR is now only available in a 17", I needed to get the internal beadlocks for that wheel size. That means I have to replace my current 15s. At this moment I'm looking at JL takeoffs with an adapter spacer.I’m interested to follow the install and read your review.
Had that been the case, guess who would have owned two sets of bead locks? I'm not unpacking that shit.My hope against hope is that the first box that was about to go out received the same careful treatment!
Two are free from the block. I had to take a quick break before tackling the others...
You'll need a pretty big spacer/adapter. I'm running a 1.25" thick adapter on my JK wheels. They are backspaced from AEV at 5.25, so I have an effective 4" backspace. My new tires rub the control arms (just) at full lock.This will be a winter project. Once I found out that the 35" MTR is now only available in a 17", I needed to get the internal beadlocks for that wheel size. That means I have to replace my current 15s. At this moment I'm looking at JL takeoffs with an adapter spacer.
Were you popping beads often (often is a vague term here) or is this more or less a preventative measure?This is the snorkel thingie that passes around the inner tube and beadlock casing to allow for inflation and deflation.
As I understand it, the old Staun internal beadlock version was filled with a Scotch Bright scrubbing pad type material that allowed air to pass through while preventing getting crushed by the beadlock. The problem was that as the rolling tire flexed, the scrubbing pad would eventually break down and crush, blocking the air flow.
Coyote's version is really clever. Instead of the compressible scrubbie pad, they use a thick plastic zipper to keep the airway open.
Blaine and I were just discussing this. He pointed me towards @Midnight LJR's old set of JK Quadratec Moab copies.You'll need a pretty big spacer/adapter. I'm running a 1.25" thick adapter on my JK wheels. They are backspaced from AEV at 5.25, so I have an effective 4" backspace. My new tires rub the control arms (just) at full lock.
I still think the MOAB is some of the best looking wheels on a TJ.And they are polished aluminum and look closer to the original TJ Moab wheels I used to have.
I've popped a few. People around me are popping more often as well, so it is also preventative. Plus, once the tires are locked, it's one less thing I need to be attentive to while aired down. Meaning, I can be a bit more aggressive.Were you popping beads often (often is a vague term here) or is this more or less a preventative measure?
