2002 TJ new problem surfaced this year. Try to start Jeep and dashboard lights go on but no crank. After a few trys and for no particular reason or change, then it turns over. Sometimes it will start on first try, sometimes after a few tries but lately we try for 5 minutes and then suddenly it starts. I had the Neutral safety switch changed recently in hopes of that being the culprit but then just had the same problem yesterday. Is this possibly a function of the ignition switch? Also worth noting that when i turn the ignition off after a drive i hear a quick “tapping “ sound from within the steering column near the key position but have no idea what that could be either. Maybe it’s related
