if you have rust free fenders it might be worth the effort.
fender goes up to the bead line on the tub. you can choose to keep the factory inner or remove it and use an aftermarket kit. i didn't like the way you have to bend the front around the grill so i actually cut it and tucked it some.
cutting the hood i was a bit OCD and taped off both sides and slid a jig on the fender to make a nice straight line just below my guestimated finish line would be cut that then set the hood back on and slid the pencil down the edges and recut until i had it as perfect as i could get it, the pencil on it's side on the fender makes a nice 1/8 gap line.
there are other small details if you decide to tackle it. .you gotta bring the battery up some too.
2yrs later i couldn't stop the top deck cancer and had to give them up. so if your not sure about um............
