While checking the jeep for the tick. I noticed right where the transmission meets the oil Pan I could feel air blowing. Is this normal? I am including a photo of the spot. Btw I was removing the spark plug from each cylinder to see if the noise was different to partially rule out piston slap. On the photo you can see the lip of the transmission you can feel air coming from.
