Hello,
I’m regearing my Dana 30 to 4.88 and this is only the second time I’ve done gears.
I think my pinion is a bit shallow and wanted input. Do you think a .003 shim behind the pinion should be good or would you go thicker. And also it looks to be hitting the heel a bit and should I decrease the backlash a bit I’m at 10 thousandths in 3 spots and 7 in one. The manual says 10-15 thousandths on backlash for new gears but I’ve read and seen videos where they go 6-9 for backlash on new gears.
Another question I have koyo setup bearings and timkin for the final setup should that make a difference as well?
