I've spent a few hours in the forum doing research, after my Jeep refused to start this morning out of nowhere.
I thought I reconfirm my finding with you guys, in case somebody else has any idea - or ends up having the same issue.
I own a 2002 TJ here in Thailand, and we don't have any Jeep dealership in the country. The car is an import and I order all my spare parts on Amazon.com. Also we don't have any legit car dealership on the island where I live at - so nobody with ODB readers or anything at all.
As already mentioned my Jeep refused to start this morning.. it started but shuts down after 2 seconds.. and the yellow key light came blinking on. I thought ok.. key dead for some reason, let's use the other one I have (bought the jeep used 7 years ago) .. but same issue.. tried unplugging the battery for an hour.. same issue.. unplugged the SKIM reader for 15 minutes.. same issue. If I unplug the SKIM module, it does crank but not start at all, and there is also no key lamp in the dashboard on. I tried to locate the grounding for G302 but had no luck so far (if anybody has a picture of that).
I checked all fuses behind the glovebox, but I didn't see any post referring to any fuse for the SKIM anyways.
There is a very basic locksmith on the island, who confirmed that the chips in both keys are totally fine. So it's either the SKIM module or the ECU.. which seems in both cases I need a new ECU sind the old one wouldn't work with any used SKIM module, and I have nobody here who could reprogram anything or has the skills to do so.
Since I'm kind of stuck (literally) my only idea is now to get a new ECU (with SKIM disabled) somehow via express shipping from @Wranglerfix or if @mrblaine has any other ideas.
Thanks for any feedback
