It’s always windy on the west side of the valley.
Lots of explaining to do @Alex01
I love the way @Lonewolf posts a picture of a rig that is so well known everyone knows who's it is.
And then @Alex01 comes back with " @Lonewolf was down to 2 wheel drive at this time so we had to drag his rig through the crossing and out of the trail "
5 wheel drive got us off the trail. I forgot just how much of a difference a front locker made. It also took me a moment to realize that I had to keep the front locked since it was just sending power to the side without a shaft.
Yea it was definitely a bit of a shit show but it was fun. I ended up breaking a RCV or the locker(still need to dig into it) and was able to limp it back to committee and Alex drug me up the hill which was no small feat! There was more snow than I was expecting as well.
I'm really getting my moneys worth of the revolution warranty this year.
stub shaft is the one with the busted joint still attached.
They did last time because I'm using the ujoint they included with the kit.
I am wonder however if its time to either move to the stronger USA made version or go all out with rcv.
The downside would be that I'd just be moving thr fuse into the locker or axle shaft joints.
What do you think is causing these to happen again ?
Turning too much trying to find traction would be my guess. It only really happens when I have the wheel jacked all the way one direction or the other. The stops look fine and the psc doesn't appear to be in the wrong place.
You seem like an rcv candidate. Engine torque×first gear×5:1×axle ratio has gotta be laying down 10's of thousands of lb ft of torque to those shafts!
Pretty quiet over here. Anyone got plans for a run this month? Xmas tree run maybe? Snow? Hello, McFly!
