Chessehead New Member Joined Sep 6, 2023 Messages 2 Location Central Oregon Dec 5, 2023 #1 Has anyone put an aftermarket hard top on an LJ? I see there are a few different ones out there.
Steel City 06 TJ Expert Supporting Member Joined Mar 12, 2019 Messages 4,516 Location Pittsburgh, PA Dec 9, 2023 #2 @jscherb is the designer of the Gr8tops one that is available for the LJ only. That one I've seen a few of [Edit: corrected by Jscherb. There is indeed a TJ version.] Last edited: Dec 10, 2023
jscherb TJ Enthusiast Supporting Member Joined Feb 13, 2020 Messages 829 Location Elmira, NY Dec 10, 2023 #3 Steel City 06 said: @jscherb is the designer of the Gr8tops one that is available for the LJ only. That one I've seen a few of Click to expand... It is true that I designed the Safari Cab that Gr8Tops sells but not true that it's for the LJ only, there is a TJ version as well... https://gr8tops.com/shop/jeepmodels/wrangler-tj-2/tj-safari-cab-full-length-hardtop A Gr8Tops LJ Safari Cab: Chessehead said: Has anyone put an aftermarket hard top on an LJ? I see there are a few different ones out there. Click to expand... Are you looking for reviews of specific aftermarket hardtops or some other information? I can't answer about other hardtops but I can answer any questions you might have about the Safari Cab. Reactions: chili_pepper, Steel City 06 and SkylinesSuck
