Hello fellow Wrangler people. I'm hoping to replace my front sway bars soon. Do I need to put the jeep on jack stands to do this or can I just chuck the wheels and replace them while the jeep is on the ground?
Thank you!
Thank you!
Thank you!
Thank you!
Thanks guys - and sorry - Sway bar LINKS.
Iirc will need a jack but you can do it in the driveway
I just did my entire new lift suspension, dampers, and bushings, and seay bar links in my driveway this summer
What is the jack for?
Not necessary, but easier if you remove the tires.
Having 2 jackstands will keep the axle level.
