I don't plan to tow far or often really. Just trying to understand how concerned I should be regarding towing capacity, and if it should determine what gears I get. Mostly looking for a decent DD that can tow occasionally.
At first, I was thinking that with the RAM example above, that I should not get the 3.21 gears because towing capacity is much less when compared to 3.92 gears. After reading it seems like either will be fine, but 3.92 would be better. Problem is most RAM trucks have 3.21. Only the Rebel seems to come standard with 3.92. The Rebel is only in my price range if used and I'm not crazy about the red trim inside.
At least The Tundra makes it easy. There are no options for gears, all of them get 3.31 and there's only one tow package. You either have the tow package or you don't. Whereas Ford seems to be the most confusing with multiple tow packages, gear ratios, and engines.
