ok perfect. And does it matter whether it's sat for 30 minutes or 30 hours, it behaves the same?
Always been that way since i bought it last Feb.
Seems you have a fuel pressure issue. Need to test the pressure at the fuel rail and see what's going on. Possible causes can be bad fuel pressure regulator, bad fuel pump or leaking injectors.
If battery was PROPERLY load tested than perhaps the cold weather with the constant cranking are too much for it.
Sometimes if I shut it down for 15 min she starts on first try
You are amazing thank you soo much !!
