Hi TJers,
I need to route a 8mm cable from the main battery to the auxiliary battery in the back. What would be the best spot to get through the wall between engine compartment and the inside of the car?
I thought I could go through the holes for the removed A/C but that ends up in the black box for heating, so that doesn't work unfortunately.
There are a few rubbery plugs in that wall but quite low, so I could get wet feet if it rains.
