I hate to say this but I've been thinking it since you said you have the vacuum leak on the coolant... Do you think the head gaskets are leaking?
I'm an amateur when it comes to internal engine diagnosis. Curious if there is a way to check to confirm it is a head gasket leak - before just replacing them.
Sorry to say this possibility but I assume you've already run through this possibility yourself...
Yes to test the head gaskets you do what is called a leak down test. It's almost like doing a compression test but instead of cranking the engine over you're applying compressed air into the cylinders. You test one cylinder at a time.
But to clarify things it isn't a vacuum leak it is a coolant leak. I have a vacuum coolant filler. This puts the cooling system under vacuum and helps to fill systems that have a problem with air pockets. There of course is always the chance that the head gaskets have a coolant leak.
I'm going to run the engine today and see if I can find the leak once it gets up to operating temperature since using the coolant pressure tester hasn't shown me the leak yet.
They could probably get way more articulation out of that treadmill if they 4-linked it...
Should it get an Antirock or Swayloc?
You guys are too funny...
