So you’re using LED in your Hellas or did I read that wrong?
Sorry, I’m stupid. I read it wrong. I understand now.
No.. Maybe I missed the flow of the earlier posts.. I was using Hella bulbs in a Toyota/Koito H4 light kit. I tried a few LED bulbs but they all sucked. Prior to the H4's I tried a few inexpensive LED headlights and hated all of them. Maybe I am a light snob.So you’re using LED in your Hellas or did I read that wrong?
Superb lighting. Great pattern. Choice of temperatures. And period correct look. I didn't care for any of the modern looking or bug-eyed LED headlights on a twenty-four year Jeep. You can't tell the Holleys are LED even if you get right up to them. Only giveaway is the daylight temperature.Good to hear. They seem solid from recent posts ive looked at. I didnt want to change up the look too much
I pulled the H4 kit and switched to the Holley Retro Brite LEDs. Love them.
From a while back when first installed...
Toyo H4 with 80/100 bulbs on the passenger side. Holley LEDs on the drivers.
Choice of colors.. warm incandescent if that's your thing (same as the H4 pictured above) or daylight, which is what I have. You can swap out the light module (Made by Morimoto) if one should burn out or if you want to change the color. The lens is made by Phillips.Wow, that’s a big difference in color alone. They look great. What are you thoughts on dark spots with them?
If you mean pattern/coverage? I don't have any brick wall shots to show the cutoff but they are nice and clean. High to the right and cutoff low to the left.
This is low beams...
This is high beams. Low beams stay on when high beams are turned on.
I have a set of Hella 500FF H3 driving lights that are aimed right up the middle. Rarely need or use them but I do occasionally. I read some concerns about the lack of heat from the LEDs being an issue with snow and ice so I thought an aux set of H3's might be wise. As it turns out, I have had no issues with the LEDs.. two or three North East winters so far.
Like I said.. I have zero regret with spending the money on them. Love them. I think you will too. Plug-n-Play. I left the Koito HD harness installed only because it was more a pain to remove, but they are totally plug-n-play with stock harness. LEDs are really low draw.Very clean. Just ordered em.
He watches a lot of scary movies. He’s skeered of the dark.
Boog, what’s the scariest of all scary movies?
People Under the Stairs?
Maybe.. Maybe...Ive been playing with hi intensity headlight conversions for 21 years. HID, LED, etc
Im running these in a 78 Camaro for a few years so I bought them for the Jeep also. Im sure we can find things to nit pick about every option, but diminishing gains rule applies
They work great for my purposes @~$70
https://www.amazon.com/gp/aw/d/B095KCKFPC?tag=wranglerorg-20
Maybe.. Maybe...
Can't get over the look of them. Just wrong for a 25 year old Jeep. Just my $0.02
Spot on.Cant get over the look either. Just happy we have options to decide what works for our own jeeps. I also think headlights are one of the few things worth paying for
.....just affordable.
