What else should I do after an OME 2" lift?
Chief Brohician
'98 TJ Sport '11 Extreme Camper '18 JLU Sahara
Lifetime Supporting Member
Guntersville, AL
I have an Ole Man Emu 2" lift. JKS Quick disconnects sway bar links and a JKS adjustable track bar were also installed. As well as new bump stops.
What else should I do? Tummy Tuck? Any upgrades for the rear?
What are all the parts I need to swap over to the XJ steering from the stock TJ Sport steering?
The rear is slightly lower than the front. I would hate for people to think I am endorsing the Carolina Sag trend that IMHO is so eff'n stupid it is dumb. Is there an easy solution to make it level or with a slight front rake?
1998 Wrangler TJ Sport
I have a wench. :ROFLMAO:
Yes, front bumper w/ winch & a rear bumper. That is on the list.
Oh, wait. Winch on the front will help with the leveling. I gotcha now. You are correct :ROFLMAO:
Reactions: JMT
Everything you can is my answer- this is what I did after my 2” OME lift -
Genright fenders
4:88 gears
Chromoly axles
Clayton arms
Savvy cable
Aluminum skid
Slight tummy tuck
Bartacts
Bed rug
Bed tred in rear
Double Din with back up cam
Hood vents
ZJ steering (direct bolt up)
Bead locks and Coopers
Centramatics
Adams shafts front and rear
Seat heaters
Vision X Cannons
Winch
UCF rear hybrid bumper
  • Wow
Reactions: Chief Brohician
I wouldn't go too heavy on the big items (tummy tuck, axel, lockers, etc) until you start getting into places you may need them, or other upgrades necessitate them.
You'll learn what you need in time.
Meanwhile, go wheel the snot out of it.
You can get some spacers for the rear if you need to. When i did the ome lift i needed spacers in front. All depends on the jeep.
I suggest a small folding shovel ,camp axe,tow strap,hooks front and rear as a start.
Check out the build thread section and look at lots of builds. Or maybe not,you'll get too many ideas🤣
Tummy tuck would help a bunch with clearance. Though you might need an sye and bodylift. It snowballs quick from now on.a lot of mods are interdependent.
What do you need? Help. 🤣
Get off-road and let the Jeep tell you what it needs.
Genright fenders
4:88 gears
Chromoly axles
Clayton arms
Savvy cable
Aluminum skid
Slight tummy tuck
Bartacts
Bed rug
Bed tred in rear
Hood vents
Centramatics
Seat heaters
Vision X Cannons
Winch
Wow. @AndyG you have done a lot since we last spoke. I will have to call or stop by to talk about the XJ steering and the Double DIN install. I have a good idea but have some questions.
Let's see pics of the 2011 Jeep Camper.
Right now, I only have pictures of the camper with the 2018 JLU Sahara. I plan on opening it up memorial Day weekend and take it camping the second weekend of june.
Edit: I will find the pictures of the interior and post later.
Reactions: AzJeff
