Stutter / Misfire - No Engine Codes, Running Out of Culprits
LngJeep
Maryland
Hi everyone, I held off as long as possible to post by using all the great resources but am now looking for those with more experience insights. This is a long one so hang in there!
Background: 2006 LJR, 6MT, ~119k. I purchased it in Sept. 2023 and have been slowly working through all the maintenance and refresh items. I'm not 100% sure when the issue started. I don't recall hearing it when first purchased. The first time I noticed was in November while idling next to a brick building waiting to plug in for inspection. That prompted me to spend time outside of the Jeep and it's much easier to notice/hear.
Symptoms: There's an intermittent misfire/stutter noise from the exhaust. It's not noticeable during cold start but I'm fairly certain that's because the higher RPMs mask it. Via scan tool, when it stutters there's a definitive dip in RPM (15-30) that causes a slight vibration and the noise. It's intermittent in that it could go 10-20 seconds or it could do it almost constantly for 10-20 seconds at a time. It doesn’t really introduce any drivability issues. It’s not noticeable other than idle (Though based on the scan tool I believe it still has the RPM variation).
I'm going to try and break what I've done and what I think I have left by the general vehicle system so they're not in chronological order per se. I also did these more or less 1 at a time to be sure to not introduce multiple variables.
Video on Youtube. Ignore the knocking sound in the beginning (that’s my son smashing something with a hammer). Easiest to hear from :20 to :27. Again, it’s a chuffing type sound
Ignition:
  • New spark plugs – tried both the Autolite and Champion recommended here (gapped properly) – no change
  • Coil pack – replaced with Viper style – no change
  • Ran Seafoam – no change
  • Battery is ~8 months old
Fuel:
  • Pressure tested system and all in spec. Didn’t see any major fluctuations during idle
  • Injectors – ohm tested originals and were OK. Replaced anyway with rebuilt 4 hole - no change. Noid light tested and all appear to be getting the proper signal – no change
  • Ran fuel treatment for a tank – no change
Vacuum systems/leaks:
  • I spent a quite a bit of time smoking everything and didn’t find any vacuum leaks. The one place I got smoke was around the throttle body butterfly (Where it spins). I followed the process for removing and replacing the o-rings. That made a significant change with only a slight leak when building full smoke pressure on the intake side of the butterfly and butterfly closed. No change to symptoms
  • I found my vacuum reservoir was somewhat collapsed and cracked. Oddly enough all my HVAC controls worked. I still went ahead and replaced the vacuum reservoir
  • PCV – I never had any smoke leaks via test. However, I could hear a high velocity air noise from it. I replaced the line on the rear of the valve since it was partially collapsed – no change. I also swapped in a new replacement gasket and PCV elbow. Same noise. I’m assuming that’s just the air moving through the restricted orifice. collapsed under vacuum
Sensors:
  • IAC –
    • Cleaned via Jerry’s process – no change
    • OEM replacement – no change
  • TPS –
  • MAP –
    • cleaned only – no change
Exhaust : Replaced after purchase to comply with state (added muffler)
  • O2 sensors – replaced all 4 with NGK recommended on the O2 sensor thread – no change
  • I pressure tested the exhaust system (vacuum blowing into exhaust) and soapy water
  • Reasonable leak at final bend at rear axle (slip fit connection). Tried new clamp but no luck. Not sure if this would have an impact?
  • Small leak where single/downstream cat connects
  • Small leak at exhaust manifold and pre cats connections. I tried to snug up these connections but couldn't eliminate it
Wiring:
  • I’ve been cleaning up/replacing wire insulation. I haven’t found anything that looks to be an issue
  • I read about the wiring that runs across the back of the engine. It looks OK but in that it’s not worn through the tape/loom. I can pull it though and double check
Engine:
  • Compressions Test – good (all right at 180)
  • Leak down test – good. Some very light from the valve cover via oil fill cap. Some very light from the exhaust with hear to it and complete quiet. Gauges read OK for leak down. I had read that a sticking exhaust valve could cause the chuffing sound but based on the leak down, all good. Or if it’s intermittent could it still be a cause?
General troubleshooting via scan tool:
I’ve tried to spend a bunch of time to see what I can monitor that would help troubleshoot the problem. I attached some pictures showing the RPM dips and some other readouts. What I’ve seen/paid attention to:
  • RPM – visible drop in RPM when the stutter occurs
  • O2 voltage – from what I can research and my limited knowledge they appear to be behaving as they should. I’ve really only been paying attention to the upstream sensors
  • MAP – I’ve been looking to see if this has strange signals since it’s a sensor I haven’t replaced it. When I get a BAD stutter, the MAP signal does change
  • When a major stutter occurs photos show examples):
    • MAP will increase (for example 40 to 42-43)
    • O2 voltage changes (seemingly reacting to the issue)?
    • The timing advance changes (expected, right?)
Based on the above, this is where I’m headed next but really where I’m looking for advice:
  • Address the exhaust manifold to pre-cat leak – Since I can’t snug up the bolts anymore, I’m going to replace the pre-cats (just seems worth it since I’d need to pull them anyways)
  • MAP – OEM is expensive ($150) so I’ve been holding off
    • Based on the symptoms, should this be replaced?
    • Anything else I can troubleshoot to confirm if it’s good or bad?
    • It’s odd to me that the MAP would fluctuate during the larger stutter/misfire events. Is it a cause or effect?
    • Would the MAP see impacts of something post-combustion (say leaky exhaust causing the O2 sensors to have false reading which would then adjust the IAC, which would then change the pressure the MAP would read? I wouldn’t think a change in fuel from an O2 sensor reading would impact the MAP, right?
  • IAC – Is there any additional troubleshooting I can do? Maybe there’s a bad signal or shorted wire?
  • Cam or crank sensor? Any diagnostics that can be done?
  • Grounds – I’ve done a cursory inspection but haven’t pulled and cleaned them
  • If all else fails above, a step I would take is to send the computer to WranglerFix for diagnostics. I have no other issues so this would surprise me as the issue
I have a Jamboree coming up at the beginning of August so I’m really hoping to get it sorted before then. That being said, it’s drivable so I can likely run it this way if needed. I'm also planning the full cooling system cleanout/rebuild and suspension refresh as I'm sorting this out.
Any help, advice, or other insights are hugely appreciated!
Reactions: Wranglerfix
I’d try a @Wranglerfix ecm…my pcm acted up and Mark’s PCM fixed it when I was trying to fix a transmission issue.
I had a ton of misfires reading on my aeroforce OBD 2 gauge (that I found online; it only works for the 05/06 models). Keep in mind that I read those misfires without 0300 codes being reported from the PCM. You can have a sizable amount of misfires that won’t pop a CEL if there aren’t enough misfires in x amount of time. I only know this from experience. My misfire issues were typically only in idle or near idle while the engine was hot. It wasn’t a heat soak issue with the fuel like I thought.
I’d rather confirm it is or isn’t the ECM now rather than find out it’s the issue during the trip or after you cancel. Just my $.02
Here’s some of the misfires I’d see without popping a code.
The device only reports cylinders 1-4 because it was provided for the Neon SRT folks (per AF’s response to my inquiry).
Someone else replaced their fuel injector connectors and it solved a random misfire. Despite the noid lights showing ok, why not give that a shot, i imagine they arnt too expensive and would add some peace of mind.
Thanks for the replies I’ll check into both.
@MikeE024, thanks for the screenshots and extra info. Definitely a great point and ruling that out would be a major step. I’ll give them a call tomorrow for a few questions. The diagnostic service looks like a good option. Just will put me without the Jeep for a few weeks but that will only hold up the coolant flush process. I can still work on the suspension, oil pan, and probably the pre cats.
Reactions: MikeE024
