D deitel New Member Joined Jun 25, 2024 Messages 2 Location Florida Tuesday at 7:15 AM #1 I recently bought a front disc brake service kit from Quadratec and the rotors are rubbing rub the steering spindle. Is there a difference between a later built 1999 TJ than a earlier built one? Thanks for any help.
GregBelleville TJ Enthusiast Supporting Member Joined Sep 19, 2022 Messages 703 Location Southern California Tuesday at 7:59 AM #2 Yep there's a difference between early and late 99s. Reactions: Wildman, Rickyd, Jeanfi007 and 1 other person
Rickyd TJ Expert Supporting Member Joined Jan 2, 2020 Messages 4,371 Location North coast,CA Tuesday at 10:04 AM #3 The rotor and unit bearing are different matched sets between early and late. You can use either on a tj so long as the rotor matches the unit bearing Reactions: Wildman
OP D deitel New Member Joined Jun 25, 2024 Messages 2 Location Florida Tuesday at 11:54 AM #4 Thanks for the info.
