Did some searching and wasn't able to find anything. My 2000 has an 03-06 hardtop but didn't come wired for it from the factory. Using the write up by @Jamison C I got the dash harness and tub harness replaced and all hooked up along with the switches. Defrost worked good but the rear wiper wasn't going. I checked the plug going to it and it was getting power, figured the motor was bad, no big deal. Ordered a replacement and swapped it out. Plugged it in and still nothing. Double checked to make sure power was going to plug and it was. I looked at the wires and noticed that the power wire at the motor and the power wire at the hard top plug were on opposite sides. I used a jumper wire to connect the two and the motor is working so I know the motor is good. I swap the two outside wires in the plug to the opposite sides and plug it in. Wiper is going and looking good. I go up front to switch the wiper off so I can button everything else up but the wiper isn't stopping with the switch in the off position. I pulled the dash bezel to check the switch and the plug to it, I unplugged the switch and the wiper is still going. There's obviously constant power going to it from somewhere, I'm not sure where to go from here to try and figure out where it's coming from and how to fix it. Any help is appreciated.
