I have a 97 sport TJ that has never let me down. To the point I passed it down to my son. It recently started the stalling and shutting down at hotter operating temps. Like most, the CPS code was the only code. I did read that cheap sensors fail so opted for a NTK Sensor. Replaced and upon initial start runs fine. Then it reaches operating temps and does the same as before. I tried all of the manual relearn procedures like, pull ground off touch it to positive for 15 secs. Mash brakes for 30 secs to dump residual volts. Reconnect battery, turn key on, turn lights on then off. Turn key off and then start. Nothing has worked and I'm wondering if I have to have an OBD to do the relearn? It's a manual and has the 2 bolt sensor so I wouldn't think it would need the .034" spacer, but I've been wrong many times before.
Thanks..
Thanks..
