How did you run the wiring for your pillar side lights?
azroc909
Big Texas
Anyone have pictures showing how did you run the wiring to your side pillar lights? I can’t seem to find a way to run the wiring without drilling a whole through the firewall or having the wire kinked / damaged.
Thanks in advance
I ran the wires along and under the vent cover on the cowl. You remove the wiper arms and then a number of screws and the cover will come off. You can then run the wires neatly and into the engine bay along one of the seams. The wires are not pinched too much and there is no drilling.
These are not the best pictures and I can take more if you need them but they should give you an idea.
Oh, I thought you were concerned about having to drill a hole through the firewall for the wiring.
Reactions: azroc909
