Learn something new every day.Right where the hardtop mates to the body at the rear side of the driver or passenger door, there should be a piece of black rubber that sits on the corner or the tub.
Looks like this:
Looks like this:
Yep you’re missing your musket seals. What are you doing about that water? You should pull your floor pan plugs until you get some new sealsOdd, I have that seal, however everything around it has dust on it. I would guess that if the water had been coming In right there that it would be clean down to the floor. Also the side carpet piece is dry while the floor piece is wet.
This literally just happened to me but it was the front of the passenger seat. I’m trying to find mine as well but I think it has to do with my carpets not drying all the way from last timeIt's been raining here and I have a puddle behind the passenger seat. Where would the leak be at that would cause this?
If I'm interpreting your description right, those would be the mounting screw holes for the soft top rear window cross bar.Learn something every day. I just got my Jeep and have leak issues. I too am missing the musket seals. Are there any other seals that the hardtop should have? My tailgate looks like something used to be bolted to either side of it, but now there are just two small holes on each side. Is something supposed to go there as well for the hard top?
