My TJ has the JW Speaker Evo 2 lights (PO liked expensive stuff). @BuildBreakRepeat has ProComps. To my eye, his ProComp lights are equal to the JWs.
I have the heated Truck Lite LEDs and am happy with them. They melt the snow and ice pretty quickly. I also strongly considered the heated JW Speaker LEDs, but cost won out.I have tried 7" LEDs on my other car. I had a real problem in wintry-mixed inclement weather with the lenses freezing up and really affecting visibility-not enough heat is generated by the LEDs to keep the lenses ice-free.
I pulled them off and put on the JW Speaker lights with heated lenses, and that is what I would go with if I ever put LEDs on my Sahara.
Are those the front turn signals or the sidemarkers? Sometimes the sockets go bad. I've had to replace a couple.Parking lights not working on my jeep. The back parking lights work no problem. The fronts work only as turn blinkers and emergency blinkers. I cleaned the connectors, still not working. I noted some jeeps have 3 wires while mine is only 2, could this be the reason of absent parking lights?View attachment 174446
Yes its front blinkers, not sidemarkers. The headlights are cheap led lamps from china. I installed it as i had plan to install 90ies japanese yellow fog lights, it pretty rainy and foggy here, i dont need headlights.Are those the front turn signals or the sidemarkers? Sometimes the sockets go bad. I've had to replace a couple.
Are you using LEDs anywhere in the system?
I'm not familiar with how the international models are wired, but with the domestic US models, the sidemarkers have to be converted to a 3-wire setup in order to put LEDs in the front.Yes its front blinkers, not sidemarkers. The headlights are cheap led lamps from china. I installed it as i had plan to install 90ies japanese yellow fog lights, it pretty rainy and foggy here, i dont need headlights.
Interesting. The headlights shouldn't affect the circuits, at least with what I'm used to seeing.Here is the lamp itself, its not led inside blinkers, only headlights are led. Parking lights didnt work even with halogen hella headlights. There are 2 core springs insideView attachment 174448
I have these and have not regretted them one bit. They are amazingly bright and of very high quality. I got them about 2 yrs ago for around $450. I think there was a coupon or a sale going on. Look around for them, and I'm pretty sure you can get them for less than the Quadratec price.I've got these vision X vortex in my shopping cart from quadratec and am almost ready to buy. they are 679.00 for the pair. Is there anything better that I should be buying, or is this going to perform as well as I expect them to?
That is more or less the same way I see it. Specially when people lift their vehicle and do not re-aim the lights after doing so.I paid for the original product not necessarily because of how the light looked from the car, but more over concern of what it would look like to an oncoming car. Good LED headlights have an asymmetric beam that illuminates the side of the roads without blinding oncoming traffic. It annoys me how many Jeep owners (especially JKU owners for whatever reason) buy extremely bright lights with poor optics and/or fail to aim them.
In addition, the diodes themselves are very likely higher quality. When LEDs (the actual diodes) are produced, they are tested and then binned according to power output and efficiency. High quality ones are sold at a premium to high end manufacturers like Rigid. Low quality ones generally go into the knockoffs and the Amazon specials. This happens even when the knockoffs are made in the exact same factory as the name brand items.
The low binned LEDs are less efficient and produce less light, and have a higher failure rate. So not only are you paying for a pattern, you're paying for a higher grade diode.
My cheap Chinese knockoffs are at least better & brighter than what the factory installed.
But the halos of the Vision X...the halos alone are worth $500. You have never seen halos like these (sarcasm). . LolI'm with Jerry here. There are some things i don't mind buying knock offs of.
These work fine for alot of us. And i have way more areas on my jeep to spend five hundred dollars on than headlights. A lot of us run these for $65.
https://wranglertjforum.com/threads/replaced-headlights-with-truck-lite-knockoffs.6239/
$500 for headlights just will never be in my budgets. Maybe I am to old! Lol. Idk. If i needed $500 worth of lights... Hell I am never going to need $500 worth of headlights. Lol. But to each their own.
You know, you can start a new thread about your parking lights. Just Saying.Parking lights not working on my jeep. The back parking lights work no problem. The fronts work only as turn blinkers and emergency blinkers. I cleaned the connectors, still not working. I noted some jeeps have 3 wires while mine is only 2, could this be the reason of absent parking lights?View attachment 174446
