There are 3 HVAC actuators on the 1997 TJ as shown below. I order the OMIX actuators replacement arms as my center vents do not work, I only get defrost and floor. Now here is the question: OMIX has 2 replacement arms Part # 17910.0 (door lever lower AC Panel) and 17910.02 (upper level defrost door). I cannot find a panel demist arm replacement part #. Can anyone confirm the 02 part number is the correct one? the 01 part number seems to have a longer arm. I only got pieces of the broken one out but pretty sure the 02 part # is the replacement. I have googled it and see all kinds of posts on the very well known issue but I cannot find conformation of the part number for the "panel demist door actuator arm"
Thank you
Terry
Thank you
Terry
