I’d appreciate your thoughts...
I’m getting close to cutting my losses on this TJ every time I take care of an issue it’s as if it’s cursed. What I’ve done lately, new OPDA same old factory CPS, new Dynomax muffler, front and rear pinion adjustments, unplugged and inspected the MAF.
with roughly $22K in work done in the last 3 months this thing should be purring and sometimes it is, sometimes it isn’t. I do have a couple clues to draw my attention to the new remanufactured transmission, but no codes, no check engine light.
Clue 1, I’ve noticed lately backing out of the garage it takes a few seconds after dropping it into reverse and giving it some gas before it begins to move...
clue 2, checking live data the calc load is at 25.5 at idle and I’ll have to take another look test driving again to see if the value changes any. Calc load represents available torque based on the throttle body sensors air density and transmission input(?).
clue 3, driving home picking up take out I noticed it felt like it was surging just a little and I began to feel the vibrations returning my thought at the time my pinion somehow was still off. Taking a look when I got home it’s still where it was when I set it, taking a 24” long caliper the drivers side lower control arm was 399mm long and the passenger side measured 405mm center to center on the bolts a 6mm difference, not sure but other than tire wear probably no going to cause the driving issues?
OK, just those three things so far point to the transmission as my first guess
the MAF/ temperature calculation sensor was showing very high values but I didn’t question it too much it’s been getting within 10-20* of the engine temperature, yesterday I’d pulled it out to install the new sensor from summit racing the connectors were different so I put the old one back in, now it’s reading much lower, very different but in more normal range I believe at 151*.
checking the spark advance after switching the OPDA yesterday it looks normal.
the remaining live data all look in the normal range I think.
