All you are going to change is the sound. If you want it louder, have at it. Wont be faster though.Hi guys.. i want to improve my tj’s performance. So i want to change factory exhaust system on it..is it good idea or not.. what would u Recommend? Thanks
Automatic and 31’s on my tjJust leave it be.
If you are REALLY interesting in more power you will build a stroker or swap a V8.
Just enjoy the 4.0 for what it is.
What gears and tires to you have now?
Speak for yourself. I shift around 3.2k and try to cruise, highway or not, around 3k. These engines love the 3k-3.5k rpm range. Let it live a little.Jeeps need Torque. Not Horsepower. We rarely rev over 3k, and that is on the highway. 2k or lower on trails. So even if the exhaust could gain HP it wouldn't appear until well over the rpms that a Jeep runs. Sorry.
Ok you have a 2002 automatic which means you have the 3-speed 32RH automatic. You also have very slightly oversized tires which in and by itself reduces performance since larger tire diameters reduce engine rpms at any given speed.Hi guys.. i want to improve my tj’s performance. So i want to change factory exhaust system on it..is it good idea or not.. what would u Recommend? Thanks
I've seen you recommend this a few different places but don't see much discussing on what comes out behind it. What's the recommendation there, if any, that would mate well to this header?Sorry buddy, but contrary to popular belief you are NOT going to gain any realistic power by replacing your exhaust system. This is a long perpetuated myth that has no basis in reality.
Now, the exception to this would be if you went with a full long tube header system and a tune, such as this one:
https://americanracingheaders.com/collections/jeep/products/jeep-1998-2006-tj-4-0l-long-system
With that setup and a good tune, you could realistically expect to pick-up 20-30 WHP.
But just replacing everything from the cat back, that won't do anything for you other than increase sound in most cases.
Nothing is going to mate well to this other than a custom exhaust. I’ll have something for you soon as I am going to be installing mine in the coming few weeks, which means a custom exhaust to go with it.I've seen you recommend this a few different places but don't see much discussing on what comes out behind it. What's the recommendation there, if any, that would mate well to this header?
İ cant see it coz i think they were paint it beforeOk you have a 2002 automatic which means you have the 3-speed 32RH automatic. You also have very slightly oversized tires which in and by itself reduces performance since larger tire diameters reduce engine rpms at any given speed.
The question is what is your axle ratio, 3.07 or 3.73? If it's 3.07, that's the reason for poor performance. 3.07 reduces the rpms too and 31" tires further reduce them which combine for reduced performance.
Look at the 9 o'clock position at either differential where you'll find a steel tag bolted on. That steel tag indicates your axle's gear ratio, this one shown below indicates a 3.73 ratio (inside the red circle). Depending on which axle you look at, those tags could say either 3.07 or 3.08 or 3.73 or 3.74. The front and rear axles are .01 different from each other.
If the tag says 3.07 (or 3.08), that produces very poor performance. Your axles can be regeared to a more appropriate axle ratio like 3.73 or 4.10 which will substantially (!) improve performance.
And X2 to the others saying a new exhaust won't make a noticeable improvement in performance. Rarely will that happen and it certainly won't help unless your catalytic converter is plugged/blocked.
Agreed, that’s where mine runs smoothest.Speak for yourself. I shift around 3.2k and try to cruise, highway or not, around 3k. These engines love the 3k-3.5k rpm range. Let it live a little.
