Replacement mopar fan clutch arrived in the mail today.
did it in the dark with a cell phone for light... this jeep has to be the worst for getting that large nut off the water pump shaft. I fought it for a few hours last time too when doing the water pump.
attempted using the fan clutch rental tool from local auto supply shop and bent the hooks on the end of the tool again, just like last time. damn thing kept slipping off the bolt heads.
attempted chaining the water pump pulley bolt to the idler pulley bolt but saw a bit of deflection when trying to turn the large clutch nut. went through the coffee can of miscellaneous nuts and bolts and found a 2 longer bolts that fit the water pump pulley holes & managed to get the fan clutch tool behind the heads and the hub nut spun right off.
assuming it was a original, no mopar part numbers on it but it was stamped Delphi and was a bit thinner than the superseded part number I ordered.
