A few months ago I bought a '00 TJ that needed a new frame, so naturally since I have to take everything off the frame anyway I decided to start modifying it. The main things I'm installing are a 2.5" suspension lift, new rims, and 31" tires. The tub is in fairly good shape with the only rotted spots being the rear driver's side floor, the rear right corner, and a couple body mounts.
Lifting the body off the frame; I should've seen this coming, but the front is way heavier than the back with the dash and hood still installed:
Body on jack stands:
Chassis rolled out:
Cut out the rust on the corner and the body mount nut that was welded in here (this was one of 2 body mount bolts that sheared off):
Cut out the rust from the rear floor pan:
Tacked in the patch:
Patch fully welded:
Ground down the part of the weld that won't be covered by seam sealer:
I need to build a proper cart for my welder..
My taillight wiring, courtesy of the previous owner:
This explains why the wipers don't work. This thing had a rubber boot on it, which seems to have trapped water rather than repelled it:
I built a cart so I can roll the body out of the garage to work on the frame:
Rolled the frame into the garage:
That was a little over a week of work to get to this point. In hindsight I should have taken a "before" picture, but oh well. I also discovered that the PO removed the 3rd cat and welded in a piece of pipe, so my entire exhaust is one piece from where it bolts to the manifold to the tailpipe. Someone correct me if I'm wrong, but I'm pretty sure it's supposed to unbolt at the 3rd cat right? My plan is to try to get the old frame stripped this week. Anyone have a recommendation for lift points on the 4.0?
Chassis rolled out:
Patch fully welded:
