Don't really have a name or a good title yet so ? Basically, I've done basic mechanical work like brakes on cars before but that's about it. I'm buying tools and learning as I go, and having a ton of fun already.
Anyways, purchased the heep about a month ago. it's an '04 SE, 5sp manual transmission. I'm not planning on going crazy with the build, but more or less just creating this thread as a way to document what I've done to it in one place.
I really enjoy jeeps that are close to stock, so aesthetically I'll probably keep it fairly simple. So like - still debating on whether I want aftermarket bumpers or just a replacement OEM front bumper (the one on there has a bit of a dent ha, been keeping my eye out for a free/cheap craigslist bumper. and definitely planning on removing the stinger bar!).
What I've done:
cleaned up some of the plastics. much better.
old endlink had no bushings haha. easy job aside from dealing with a crummy rusty nut that stripped the threads the entire way off.
After replacing the rad / adding grill inserts. Another stupid easy job. I really like the stock grille without inserts, but I kinda wanted to protect the rad as much as possible so I added these and actually really like them.
Looking forward to really getting into this one! And who knows, maybe I'll eventually swap a V8 in haha. Gotta get my own garage first, though.. so for now I'll be enjoying my 4-banger
What I've done:
- new Rad/water pump/ cooling system overhaul
- replaced one swaybar endlink (have the other one ready to go, just gotta deal with a rusty bolt to get rid of the one on there)
- removed the first of the two steering stabilizers the PO added (will be replacing the other one once I get better tools this week)
- fluid changes
- soft top for summer
Balance tires - have a vib at 55mph+ that's driving me crazy.*transmission mount got rid of this!Remove rust / replace rusty floor pan on drivers side. Rust is still surface, so hopefully I'll get to it before it gets too bad.New trans mount- Paint/rehab floor entirely - it hasn't had carpet for years and is pretty gross / scuffed up. Trying to figure out whether I want to bedline or just rust-oleum it
- Clean up / replace rusty or old suspension components. A lot of surface rust that's cleanable, but I will need to replace a couple parts
- U-Joints and
ball joints - New Steering column
New Exhaust - current muffler is peeling apart so might as well upgrade it a bit- 1.25" BL
*maybe* a 1-2" suspension lift? need to decide on this soon because I want to replace shocks. PO had Bilsteins but it's a pretty harsh ride.paint/undercoat the frameand suspension. frame is practically rust free but I want to protect it, especially living in MArepair / replace steering box. Has a small leak that the lucas stop leak hasn't seemed to work on.
