https://rover.ebay.com/rover/1/710-...0001&campid=5337789113&icep_item=124170302456
1997 Jeep Wrangler TJ 4.0L rolling chassis with engine and running gear.
Sold for spares only. Non runner, No V5 with sale.
What’s included:
What you see is what you get, noteworthy items missing,
Must be trailered away as is, i do have contact to arrange if required. Happy to hold with a deposit if required due to lock down restrictions.
Sold as seen.
What’s included:
- Chassis, this is heavily rusted at the rear around control arm mounts and spring perch, weld repairs to front,
- DANA 44 rear axle complete in working order with brakes and all suspension mounts, brakes will need to be refurbished,
- DANA 30 front axle complete in working order with brakes and all suspension, brakes will need to be refurbished,
- AX15 manual gearbox appears in working order and was before stripdown,
- NP231 transfer case complete with front and rear prop shafts, appears in working order and was before stripdown.
- Steering system, column, box, wheel, linkages and pump,
- 4.0l engine, turns freely, mainly complete, intake and exhaust manifold, exhaust system, missing a few auxiliary items.
- Brake and clutch master cylinder
- Fuel system including tank, pump, pipes and rail,
- Wheels and tyres, front treads nearly bald ,
- Body tub, badly rotten around body mounts, grill with light housings and radiator, cowl, tailgate and bonnet,
- Heater matrix and blower,
- Wiring looms, ECU, fuse boxes
- Doors, windscreen surround, rollcage, hardtop, fenders, fender flares, spare wheel,
- All interior and dash with exception of front seat carcass and foams if required.
- Number of engine auxiliary’s, hoses and cables,
Sold as seen.
