1997 TJ heat turns off randomly while driving
The order from Amazon had an issue, and got canceled, so went with the VDO/Continental PM6002 from Rockauto as suggested. Arriving today. Will install later.
Reactions: macleanflood
New motor arrived and installed in less then 10 minutes. Seem okay, cant really tell the difference compared to old unit.
I discovered anoter issue with the heater fan speed switch, where the motor would stop work when the witch knob is on position 3, but works if i push hard on the knob. Pulled it out and found a loose pin on that #3 speed on heater control. Will need to source a new heater control.
I now also have an issue with my double din radio, wont turn on 🙃 at all. Fuse in glove box is good. More things to dig into.....
So no change, then? As in you don't have different fan speeds?
-Mac
I did state that i do have the fan speeds, just not on position 3 as it connector pin on the back of the control Switch is loose, so will need a new control switch. Other then that it is working.
Having a hard time finding the heater blower control switch for 1997
Installed a used control switch, and everything works good
Got one from a local junkyard. Most of the yards I called wanted $40-$50 for the whole control unit. Got lucky with one yard that allowed me to take just the control switch for free.
Where did you find junkyards that had 1997-1998 heater controls for $40-$50??? Could make money on these as Ebay has them in the hundreds...
Want to thank you all for your input on this issue. For less then $100, I was able to fix all the issues related to the heater blower, and now do have much more heat coming in.
Thank you all. Bless!!
