Engine turns off while driving
Northgeorgiarider
North Georgia
The 06 Rubicon 4.0 has electric power but the engine shuts down while driving. The power to electrical is there but the starter wont turn. Both time the heater has been running and both time after the heater is shut off the starter will turn and the engine will run as normal.
Any one heard of this happening or has any idea what's wrong.
1. I've checked the alternator. 13.50
2. All the engine ground have been sanded to ensure good contact and are tight.
Is it random?
A certain speed?
A certain RPM?
The more details, the better we can serve you.
Is it random?
A certain speed?
A certain RPM?
Because it's only happened twice I dont know the speed or RPM.
I can say that has happen both time while I slow down. Once coming to a red light the other turning into a side street.
No, after turning off the heater it will crank up with no problem. With the heater left on it wont do anything
Have you tested to see if when just the ventilation is on with the fan; does this have the same results ?
I can imagine the heat from the climate control system would have an impact on cranking the engine over.
