Needing some (a lot) of help chasing down running issues on my 1997 Jeep TJ 4.0 Auto with 160,000ish miles.
Short version is when it’s running, it runs great … right now it just doesn’t run longer than about 5-15 minutes
Cranks and runs for 5 to 15 minutes. Most of the time it cranks right back up and does the same thing over and over.
No engine codes on display when key is cycled 5 times
No check engine light on
What I do know …
Battery Voltage 13.2
Battery Voltage while engine running 13.9 with lights/blower on
No voltage drop on meter before engine dies.
Fuel pressure 55ish when running but does leak down after engine dies. Down to 0 in 5ish minutes.
Fuel pump relay seems to stay engaged until engine dies, then drops out in 2-3 seconds.
No drop in fuel pressure when engine dies.
New Wranglerfix PCM
Crank Sensor new x 2
TBS Sensor new (mopar)
Idle Air Controller Sensor
Distributor Ignition Pickup
Cleaned grounds with wire wheel/brush and applied dielectric grease
(2 on fire wall, 2 on engine, 1 on hood, 1 beside coil, 1 on frame from coil)
All sensors are either NAPA or Standard brand I believe.
Have swapped PCM's ... no change in anything.
Thanks in advance for any and all help
Steve
The boys want there jeep back to go riding
What I do know …
New Wranglerfix PCM
Steve
