I have a 1997 TJ Wrangler, and I recently replaced the idle control valve (IA) to fix my engine running rich, it did fix it and ran much better after that. About a week later, all of thr sudden it started running rich again and will not rev past 3k rpm, after 2k rpm I can't push the gas too hard or else the engine begins to richen up and start to die. I replaced the MAP sensor, upstream O2 sensor, and the crankshaft position sensor, none of those had worked. I had checked the codes and cleared them multiple times along the process of replacing the parts. Any help would be great. Its a 2.5L 4 cylinder.
