1997 Wrangler 2.5 Won't Start (Cranks But No Gauges)
KJMills1209
Lancaster, PA
Pulled the Wrangler out after winter. Ran great for the first few trips. Was driving down the road, about 5 minutes into the drive it shut down. Lost all gauges. Pulled over, sat for a few while cranking and it fired back up. Drove to Maryland with no issues, other than why at felt like 2 quick cut outs in 5th gear. Fired up and drove back to PA with no issues. Next trip was perfectly fine. After that, was backing out of the driveway and it died. Again, a few minutes of cranking and it fired. Pulled back in the driveway and let it sit. The next day, I attempted again to take it out on the road. Backed out and it died. Cranked for a few, fired up and pulled back in. Hasn’t started since. I did notice, that it will only fire when the dash gauges come to life. If t he y don’t come up, it will not start.
Brand new fuel pump, brand new CPS. Pins 2 and 22 on the PCM have 12v. Sounds like the fuel pump is not coming on when key is turned. All fuses are good. I’m at an absolute loss. Help!!!
SSTJ
Inexperienced Overthinker
South Carolina
Welcome to the forum. I too have a 97. Watching to see what kind of advice you get.
TJ4Jim
TJ Expert
Lifetime Supporting Member
Brookings, Oregon
The most basic first move would be removing the battery cables and thoroughly clean all surfaces and re-tighten all connections..
