Any one know if I can wire the blower motor directly to a on off switch temporarily for a few weeks while I take the time to diagnose the real issue?
You should be able to if it’s rated properly and if you don’t mind would you tell us what the real issue is?
I can pull some strings and probably get you a 30 day clearance to run a temp switch, if my supervisor @Jamison C is ok with it.
Should be easy with the battery right there and an easy hole through the dash where the heater hoses/AC routed through. I'd use a fuse and 12g wire for your temporary/permeant fix.
-Mac
Perfect any idea on a good spot to jump into the harness and what colors the wires are and what ones power and what ground? Trying to get all my info so when I run over there in the am I have the best chance of getting it rigged up
The blower doesn't work it's my father inlaws jeep and he bought a absolute rats nest it has random wiring running all over the place. He has been driving it a lot and it's getting pretty cold so I need to do something fast and easy to get by till I have time to actually figure out if it's the switch or a relay or the old owner cutting up all the wiring in the dam jeep
