- Price
- 7500
- Location
- Oxford, NC
181,700 miles
I bought this from a friend back in February. Thought I might use it as a backup vehicle and maybe do some off-roading. The best laid plans of mice and men...
So, I'm selling. I might have put 800 miles on it since I got it.
3/2/2025 - 181,500
* Redhead steering gearbox
2/14/2025 - 181,200
* Freeze plugs
* Exhaust manifold
* Manifold gasket
* Fuel injectors
* Coolant flush
* Injector rail heat wrap
* Oil and filter
* Used cruise control buttons
* LED headlights
* Adjust parking brake
1/6/2024 - 180,000
* Plugs, plug wires, rotor
9/12/2024
* Replaced Alternator
* Replace heater hose
* Replaced driver’s window regulator
1/2/2024
* Clutch kit
* Fly wheel
5/14/2020 - 172,855
* 15x8 Black Wheels
* 33/12.5-15 Centennial Dirt Commanders
4/11/2020 - 174,218
* Front pads and rotors
* Repack from wheel bearings
- 2.5" - 3" inch lift. Parts look to be Rough Country
- 33/12.5-15 Centennial Dirt Commanders - ~50% tread left
- Front/rear diff appear to be factory. 3.73 gears with Dana 30 in the front and Dana 44 in the back.
- No rust in the usual places. Frame is in good shape and the floor pans are solid. Glad to provide pics if needed.
- There's been a lot of maintenance don't recently. See the list below.
- I replaced the steering gear box with one from Red-Head Steering Gears. I believe the warrantee carries over to the new owner.
- Paint is in good/fair condition. Not faded anywhere but some minor scratches here and there.
- PO installed a CarPlay head unit and Kicker speakers in the roll bar. Loud enough to overpower the road noise.
- I had to replace the freeze plugs. While I was in there, I did new injectors and exhaust manifold in case it was cracked. It wasn't. Still have the original.
- Spare set of factory rims with brand new 235/75-15 street tires.
- New clutch and flywheel ~3k miles ago.
- Tune up ~2k miles ago.
- A/C works
- The blacking on the mirrors is faded/chipped but no damage otherwise.
- One of the POs installed LED signal and tail lights but didn't get them working just right. The fast flash when using them. (Turn signal relay, maybe?)
- The dashboard gauges stopped working a couple of weeks ago. I haven't had time to fix it but can do so before selling if needed.
- The windshield is cracked. I don't think it'll pass inspection as the crack interferes with the wipers. Glad to replace it before selling if requested.
3/2/2025 - 181,500
2/14/2025 - 181,200
* Freeze plugs
* Exhaust manifold
* Manifold gasket
* Fuel injectors
* Coolant flush
* Oil and filter
* LED headlights
1/6/2024 - 180,000
9/12/2024
1/2/2024
* Clutch kit
* Fly wheel
5/14/2020 - 172,855
* 15x8 Black Wheels
4/11/2020 - 174,218
