Hello,
Couple questions regarding the vacuum lines coming off of the top of the fuel tank. I just purchased this 1998 Jeep and the rubber vacuum line transitions to steel and the steel line dead ends under the driver seat and is rusted out.
Is this line suppose to run up to the bottom fitting on the evap canister and if I want to replace everything with a rubber hose, does anyone know what size hose I should use, it looks like 1/8 I.D.?
