1998 TJ, Good Battery, No Power
mrhiggs
California
Driving, check gage light on, pegged at 19 amps, turn off, won't start, no power, no lights, nothing.
Battery good, terminals connected, not corroded, no blown fuses.
Found a post with similar issue they swapped some fuses and it fixed it. Tried it and it worked (got power back) but lost power again when I went to crank it over. Also found that if I disconnect the negative terminal on the battery same thing happens, get power back but lose it when I go to crank it over.
Where's the short?
Thanks
The short would imply that a fuse blew. Not that disconnecting cables suddenly brings it back to life momentarily.
Reactions: John Cooper
What happens if you disconnect the alternator cable...you could disconnect it from the PDC rather than the back of the alternator.
Any visible damage to your PCM?
A short is any interruption in an electrical circuit, which is clearly happening because I have no power, in this case it isn't blowing the fuse.
  • Face Palm
Reactions: NashvilleTJ
I am guessing that was 19 Volts as the factory has a Voltmeterr and not an ammeter.
I doubt there is a short as that should not cause an over-voltage event.
My bad, 19 volts, I don't think it was a true over-voltage event. I think the short fed a false reading to the voltmeter.
Disconnected, blew out some dust (no visible corrosion), started right up.
not my Jeep
Reactions: macleanflood
Not 100 percent what you did but fixed is fixed.
Newer TJs have bad PCMs and crappy wiring harnesses.
