Just got my 1st jeep. My plans are to have a nice driver that is capable offroad in the event i have the time to go offroading. Starting with a flame red 2000 sport. 4.0l and 3spd auto trans. I will post pictures along the way
That's a hell of a nice canvas to start from!
Now that's digging into the project!Added rear disc brakes because i thought the drum brakes were making noise. Once i had the diff opened and axles out i realized the noise was in the factory limited slip. Bought an Eaton trutrac and used stock 3.73 ring and pinion.
I got a new header.Didn't the intake manifold and exhaust manifold mount up before? Or did you change something out?
I got a new header.
Not sure i would have to check my amazon to see. Thanks for the input. I might try to cut it and if it doesnt work out i can always get a replacement intakeWhat brand is it? Might be something others have used before. I can't tell you if it's safe or not to remove that area or not. sorry I can't help you with that.
I bought it off amazon and now i cant find it anywhere on there. I found one on jegs that looks like the same one and it has a lot of reviews saying it had to be modified or it doesnt fit with the stock intake. . I guess thats what i get for going the cheap route. I tried cutting out the part that was hitting but still not enough clearance. I will have to modify the header or get a different one.What brand is it? Might be something others have used before. I can't tell you if it's safe or not to remove that area or not. sorry I can't help you with that.
